![]() | Home > Technical > Prop shaft removal |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Hi, am in process of changing prop shaft centre bearing. Managed to remove exhaust heat shield & front 6 bolts. Can only get 3 of the four rear bolts out. Access to top one out of sight and when I managed to get a socket on the bolt, couldn’t get angle/space to turn it. Has anybody got any tips?
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Let us know how you get on with replacing the centre bearing, most people end up replacing the whole prop due to inability to re-sealing it and also finding notchy UJ's. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Note the spacing between the balls is not equal.
Managed to get bolt out, thanks Andy! Just struggling to actually get prop out. Sprayed with WD40and will leave for a bit. Thanks for ball spacing advice, will bear it in mind and report back when I eventually get it done! |
put 2 bolts in loosely.
yes spraying WD40 into the bolt holes helps get lubrication where needed |
Give it a few taps with a lump hammer around the to loosen it up and it'll come off.
Poco Member Since: 16 Jan 2020 Location: Swadlincote, Derbyshire Posts: 12 ![]() ![]() ![]() |
Hi all,
Hi all.
Mine didn't go back on as per the marks, and I got away with it! |
But I haven’t had to strip the spider/ball bearings!!!
My problem was the center mount rubber was broken.
What grease do I refill with? All I have to hand is the greyish stuff (moly... summat or other!!!) the stuff for cv joints etc |
Sorry Andy, didn’t realise you had replied re grease before I posted again!
