Home > Maintenance & Modifications > Things to do during lock down
Eaters
With a bit more time on my hands and my RRS now moving, I have now repainted the silver trim on my side steps. It's not bodyshop quality or anything but a big improvement on how they looked before and not at all difficult to do.
Before:
During:
After:
I've also done all five wheels Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #597833 Fri Apr 17 2020 10:47am
Autobiography1969
Very Nice Job.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #597836 Fri Apr 17 2020 12:30pm
Eaters
Re: Things to do during lock down
[quote="Eaters"]With a bit more time on my hands and my RRS now moving, I have now repainted the silver trim on my side steps. It's not bodyshop quality or anything but a big improvement on how they looked before and not at all difficult to do.
Should have said "...not moving..."
Can't type!!! Embarassed Robin
Gone:
MGZTT 190 2.5
Post #597838 Fri Apr 17 2020 12:35pm
Eaters
Autobiography1969 wrote:
Very Nice Job..
Cheers - I'm pleased with it. Although I've already had to touch up one of the wheels - lord knows how that got kerbed again Shocked Robin
Gone:
MGZTT 190 2.5
Post #597839 Fri Apr 17 2020 12:37pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
That looks great, what did you use? Did you have to fill any pitted areas/use any primer or just spray pain straight on? Need to tidy mine up, only so far metal polish will go....
Post #597841 Fri Apr 17 2020 1:10pm
Eaters
For the wheels I used Isopon P38 on the kerbing. Then just Halfords Etch Primer, followed by a silver paint (Mercedes Brilliant Silver in my case) and then Clear Lacquer. I was guided by many You Tube videos but the card trick with this one...
&t=14s
...was a good idea I thought.
Here its being used today to touch up that new kerb rash I somehow managed to acquire!! (The cards are now silver as they've been used quite a bit what with 5 wheels already done.
I went through various grades of sandpaper and the like (from 380 to 2400 grit), and including scotch brite to roughen up the surface a bit where I was blending in to existing paintwork.
For the side steps I just Karchered them quite hard, then Scotch Brite. Then used Knifing Putty for the very small pits and gouges. However this seems to take an inordinate amount of time to dry, And you can't rub it down until it has gone rock hard. So you need to leave it about half a day each time you put any on. A real pain. And if I do any more I'll probably slightly deepen and widen the hole (perhaps with a Dremmel) so as to make sure its clean inside as on occasions I found that after applying the putty, it only stuck around the hole but not in it. Evil or Very Mad Robin
Gone:
MGZTT 190 2.5
Post #597844 Fri Apr 17 2020 1:42pm
Stevepd
I did something similar as I to lightly scotch brited my side steps and I recently did my lightly Kurbed alloy. Mine had only broken the powder coating, so as you I used varying grades of paper then used an enamel paint that I airbrushed.
I gave my car it’s pre-summer clean 2 weeks ago and even scotch brited the exhaust tail pipe that bends down. Looks like new (standard item). 2006 2.7 TDV6 HSE in Cairns Blue.
Post #597845 Fri Apr 17 2020 2:03pm
knwatkins
Looking good Robin Thumbs Up Kev
Post #597850 Fri Apr 17 2020 9:33pm
Darren Anthony
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
This has just reminded me that I need to get round to doing mine.
Want to paint them black to kind of match with everything else.
And this current time of not being able to go anywhere is indeed the ideal time to do it! 2010 RRS 3.0 TDV6 HSE
1992 Mazda RX7 FD3S
Post #597878 Sat Apr 18 2020 5:44pm
Eaters
Absolutely. I took my wheels off to do them so that I could control the environment (my shed) whilst painting. I'm pleased with the result. Not a professional finish (I know because one of my wheels was buckled and so had to go away for full refurb) but quite good enough for me. And the full refurb was £150 so quite a saving to do the other 4 at around £50 all in! Time will tell if I have done a good job. Robin
Gone:
MGZTT 190 2.5
Post #597891 Sun Apr 19 2020 7:36am
"The Devil makes work for idle hands" Whistle Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #597894 Sun Apr 19 2020 9:32am
Eaters
Oh yes! Now what about those calipers... Very Happy Robin
Gone:
MGZTT 190 2.5
Post #597898 Sun Apr 19 2020 1:28pm
