Home > General > New engine ? |
dashingdave Member Since: 20 Sep 2014 Location: Dogtown Posts: 29 |
Kev, no water in oil just to add to the mystery. The oil cooler idea worth a look, thanks. D |
Sun Apr 12 2020 12:54pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
If the the oil cooler were leaking oil into the cooling system surely it would show up as a raised water level, in addition as oil floats on water would it not also be evident in the header tank as that is the highest point. If it was the reverse it would show as emulsified oil in the engine.
Sun Apr 12 2020 9:28pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Yes, I agree Col, that's why I asked if Dave had checked if there was coolant in his oil.
Sun Apr 12 2020 9:36pm |
As far as the water finding it's own level when topped up, even my S/C does that when topped up to the level mark, no matter how many times you do it, it always drops by a small amount to find it's own level below the mark and always has done, even my old 4.6 P38 did exactly the same thing.
Sun Apr 12 2020 9:51pm |
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 |
It could be the EGR coolers failed... water leaking into the exhaust system and being evaporated... |
Tue Apr 14 2020 9:35pm |
...sadly it's looking like the head gasket probably between the water and oil galleries. Yellow sludge on filler cap and pressure in the system pushing water out of the loosened cap. When the cap was tight it blew one of the hoses off. Performance still very good. Going to try the gunk first in the shape of SteelSeal. If unsuccessful then sell on cheaply...loads of new parts last 5 years.
Wed Apr 15 2020 7:16pm |
Did you run it without coolant Dave? Kev
Wed Apr 15 2020 7:20pm |
Probably but kept an eye on it. Got test kit coming but just thinking it may test negative if not blown on combustion chamber. |
Wed Apr 15 2020 7:26pm |
(Item ID: eBay Item No. 283852829188) on eBay. The Steel Seal worked for a short time but now looking like a heads off job. I'll get a price to do but in the meantime it's advertised at £2500. |
Sun Apr 19 2020 2:19pm |
chrbro Member Since: 03 Nov 2021 Location: West Yorkshire Posts: 13 |
Found my water leak was a distribution unit in the vee so all the coolant was evaporated before it hit the ground. £200 rather than the heads off 🤦🏻♂️👍🏻 |
Mon Aug 29 2022 7:35pm |
