![]() | Home > Technical > suspension troubles |
Was it a sub £200 one from Ebay? |
markg103 Member Since: 06 Apr 2020 Location: cambridge Posts: 35 ![]() ![]() ![]() |
Hi Yes it was a cheap £125
Hi all still trying to figure out whats wrong , so i have taken the compressor of the car connected it direct to the battery and it runs fine its sucking and pushing air in and out but when on the car it runs for 5 seconds then cuts out and amber light comes on, the car is on the bumps now but took about 10 days so i am guessing its holding air reasonably OK, if i connect the pump direct to battery when on the car in order to pump the suspension up would it work or could i cause more damage.
I believe ppl have done this before
Many thanks for the reply i was wondering if i could put enough air into the system to drive to a garage if needs be or just to see if it would raise the vehicle thus eliminating the pump if the vehicle would raise, at the moment i am looking for leaks valve blocks etc but not sure if the pump would only run for a few seconds as i does if its just a leak.
swatkins Member Since: 01 Apr 2017 Location: Essex Posts: 57 ![]() ![]() ![]() |
Been through all of this brought the £125 only then the £175 one then then £180 from ebay all sent back and refunded without question, buy this one it works https://www.lrparts.net/lr023964-air-suspe...relay.html
Hi thanks for the reply i was thinking it a faulty compressor but it works connecting it direct to battery thats what confusing me i assumed if it works directly it must be ok, but thanks il take a look.
I also have a Dunlop compressor and it's been very reliable since I installed it.
Thanks guys happy to buy another compressor just trying to clarify that is the problem
Hi Guys
Disconnect battery for at least 30 mins |
OK many thanks
Hi guys finally got the car running and run a scan, the code it gave is C1131 low air supply can anyone suggest anything other than a compressor before i purchase another one, the compressor runs for a about 5 seconds then the light comes on.
Hi all can anyone tell me if if the GAP tool is the only tool that can you can purchase to setup ride height as fitted new a sensor and the suspension is all over the place.
