Home > General (L494) > InControl Duo/Pro USB Compatability |
Estrace Member Since: 24 Sep 2019 Location: AIGUES VIVES 30670 Posts: 15 |
For gps charts updates the system requests that the usb stick must be formated in FAT32 on windows10
Mon Mar 30 2020 3:50pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1828 |
You can use a 64 Gb stick.
Mon Mar 30 2020 9:04pm |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
I have used a multitude of 8/16/32gb sticks all different Sandisk models and all formatted specifically in FAT32 - I've even used different formatting software other than the built in Windows formatter and still nothing.
Mon Mar 30 2020 11:15pm |
I tried 64 and 128 stick formated in FAT32 and it does not work for updating the G P S charts |
Tue Mar 31 2020 12:15pm |
I tried only with the data files from the JLR program for updating the GPS charts and it worked as per my last post I will try to transfer standard MP3’s on a stick to In Control USB sources and let you know but it works fine with DVD’s Cheers Serge |
Tue Mar 31 2020 12:26pm |
It does work, maybe worth checking Disc05 forum if you want to know how it's done. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Tue Mar 31 2020 12:56pm |
I am not sure about your problem, but Windows 10 formatting has definitely changed at some point. I have 2 identical Sandisk 32 GB sticks and I used to randomly pick up one to use for the map download. I used to always format it before starting off the process until one day it said it was too small. I plugged in the other one and it worked OK, as the downloader overwrites the old files. I make sure now that I use that same stick and NEVER re-format it. Here is the difference between the 2, the one labelled Music has just been formatted a moment ago and the other has not been touched for over a year and contains the last map download. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Tue Mar 31 2020 3:21pm |
Exactly the same problem and the same solution for me, for some reason the latest W10 now gives only 29 GB after FAT32 format and previous W10 gave 31GB on the same sick, really funny.....
Thu Apr 02 2020 10:44am |
https://disco5.co.uk/forum/thread2157.html...p;start=15
Thu Apr 02 2020 10:54am |
Yeah something has changed in one of the feature updates and/or something changed in 19C
Thu Apr 02 2020 1:19pm |
DO you have 1,000's of MP3 files on the USB stick? If so, have you tried it with just a few? 2023 P440e SE Dynamic on order -cancelled
Thu Apr 02 2020 2:43pm |
No just 6-7 MP3s of live performances - they've always worked before
Thu Apr 02 2020 2:58pm |
I will put some MP3's on a stick tomorrow when I am on a PC with some files. 2023 P440e SE Dynamic on order -cancelled
Thu Apr 02 2020 3:23pm |
OK, I have put some MP3's on a stick called Music ( the one in the photo above )
Fri Apr 03 2020 8:42am |
