Home > Technical > Indicator/DRL lights not working after jump start |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
i think its the BCM that controls the lights but i'd do a battery disconnection first and see if it re-boots everything.. |
Tue Mar 24 2020 3:23pm |
Before you do anything, give the battery a full condition/charge as a low charge cause these issues even after jumping. It could also be that your battery is shot and needs replacing. 2019 5.0 SC SVA (Current)
Wed Mar 25 2020 3:59am |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 587 |
I had a similar issue and it was the earth strap onto the headlight under the wheel arch
Wed Mar 25 2020 9:39am |
blackedrrs Member Since: 14 Mar 2019 Location: Windsor Posts: 11 |
Thanks for those suggestions guys. I will am about to order a new battery and will be putting it in as I still have the low battery warning. I'm hoping this will resolve the issue. Will report back. |
Wed Mar 25 2020 5:24pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 529 |
Wed Mar 25 2020 9:41pm |
New battery arrived today so will be installing it tomorrow. My plan is disconnect the existing one and leave it a few minutes to do the 'reset' and also check the earthing strap. Although my battery is about 6.5 years old which tends to be the life of the average battery so it is due for a change anyway.
Fri Mar 27 2020 3:45pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
New batteries are not necessarily fully charged so it is recommended that you put the new battery on charge over night (at least) before you install it.
Fri Mar 27 2020 4:04pm |
this will help,
Fri Mar 27 2020 4:06pm |
Good news and bad news. Good - manage to fit the battery and go no adverse affects. Windows and sunroof worked as normal.
Sat Mar 28 2020 12:57pm |
Another thing I have just noticed is the the DRL are no longer on automatic on the working side. They can be manually tunred on so do work on the drivers side.
Sat Mar 28 2020 2:16pm |
The BCM is behind the glovebox, there’s not much you can do as it’s solid state. Have you read any DTCs? 2019 5.0 SC SVA (Current)
Sat Mar 28 2020 11:11pm |
It's not throwing any DTCs that I can read with my standard diagnostic tool. Is this more of a dealer job to read those codes? |
Sun Mar 29 2020 12:06am |
I would have thought a generic reader would give you some DTCs but maybe not very specific ones. 2019 5.0 SC SVA (Current)
Sun Mar 29 2020 4:30am |
Just thought I'd give everyone an update. It turned out that the issue was I blew the indicator and drl lights so meant I had to replace the whole headlight unit as these were integrated into the unit.
Fri Jun 05 2020 2:13pm |
