Home > Technical > Gearbox glitch |
Kevin Member Since: 06 Dec 2005 Location: Poole Posts: 9 |
Have you checked your tyre pressures are correct. If one is low this can cause all sorts of problems in shifting. Kevin |
Sun Mar 22 2020 12:25pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 314 |
Thanks for the reply, yes I have their all correct and front tyres are new and correct size rears are matching pair good tread. Steering angle sensor not showing an error on my Icarsoft code reader.
Sun Mar 22 2020 2:54pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4996 |
make sure the brake pedal switch isn't sticky |
Sun Mar 22 2020 5:01pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
Mine does the exact same,,, I thought maybe it was just the way I was driving at the time. Sometimes I drive with very little variation on the throttle, especially at roundabouts or junctions,,, which is where I see this most. 2010 RRS, TDV8
Sun Mar 22 2020 6:20pm |
I take it brake lights working correctly doesn’t necessarily mean the switch is working correctly?
Sun Mar 22 2020 8:34pm |
If it thinks your braking, it thinks you are going down hill and would benefit from engine braking ie a low gear |
Sun Mar 22 2020 8:56pm |
Ahh, she does tend to drop into 1st when slowing and cornering when I would normally expect to stay in 2nd or 3rd.
Sun Mar 22 2020 10:11pm |
Is it actually in 1st or is in 2nd? It could be different for other models but my car starts in 2nd unless I select first manually. 2019 5.0 SC SVA (Current)
Sun Mar 22 2020 11:32pm |
I’m only assuming it’s 1st?
Mon Mar 23 2020 9:14am |
I think it's just supercharged models which start in 2nd |
Mon Mar 23 2020 12:18pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
https://disco4.com/forum/pulling-away-seco...ght=Second
Mon Mar 23 2020 12:55pm |
Thanks for the replies and information, been out this morning and she’s driven faultless. I’ll monitor the situation and look at doing the steel sump and separate filter conversion soon.
Mon Mar 23 2020 2:22pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
That's normal for these cars. It knows you're talking about it so it's playing ball now! 2016 RRS SVR Estoril Blue
Mon Mar 23 2020 2:38pm |
Very true see how long it lasts? Steve
Mon Mar 23 2020 5:31pm |
