Home > In Car Electronics > Streetwize tracker
tess
Streetwize tracker
Ive just bought this tracker, if I connect it to the battery will there be any problem draining the battery eventually
Post #596820 Sat Mar 21 2020 6:25pm
knwatkins
Eventually, yes.
Use a USB hardwire kit and wire up to an ignition live. The streetwise tracker has a built in battery which will charge when you run the engine and tide you over when the engine is not running.
I have a TKstar tracker installed with the same method. Works fine. Kev
Post #596829 Sat Mar 21 2020 9:51pm
