Home > General > Rear brake knock noise
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Hi Chaps.
Noticed today that when applying the parking brake that I hear the normal motor noise but then hear a knock. Not always but if I apply and then un-apply then reapply the parking brake then I hear this loud noise knock clunk.
Any ideas? Will book it in anyway but curious to know what it might be.
Thanks in advance. ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #596811 Sat Mar 21 2020 5:26pm
McFarTech
Well my rob acticulator was destroyed. So that plus + rear parking brake shoes and labour has set me back £1500. Could have done with out that right now. ===========================================
Post #597018 Wed Mar 25 2020 8:30pm
Brit Plumber
What was destroyed? I’m sure you used to be able to get a kit of internals to rebuild the actuator rather than replace it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #597031 Thu Mar 26 2020 4:05am
knwatkins
You're right Brit. Usually, the gears strip inside the parking brake module. You can purchase a kit to repair this.
Part number: DA9223
https://www.jgs4x4.co.uk/discovery-3-rr-sp...epair-kit/
or, if you just need the gears themselves...
Part number: DA9224
https://www.johncraddockltd.co.uk/da9224-p...gears.html Kev
Post #597040 Thu Mar 26 2020 10:29am
knwatkins
Coincidentally, I just came across this on YouTube:
 Kev
Post #597081 Fri Mar 27 2020 5:20pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
My indie replaced my parking brake earlier this month he has them reconditioned cost was £150 + VAT. Asked me if I wanted the one he took off returned to me after being repaired , picking it up next time I'm in the area could be a while with the present situation.
Post #597082 Fri Mar 27 2020 6:44pm
Oldandconfused
That's a good price, I had mine replaced under warranty and with labour and VAT the job was £900. I'm not sure you'd want to take it off the car on your drive, looks a PITA.
Post #597093 Sat Mar 28 2020 9:08am
