![]() | Home > General > RRS 3.6l vs facelifted 3.0l |
I haven't heard of the filter problem. but yes the 3.0 engine has issues.
Having had both, I'd say 3.6TDV8 every day. It's just such a good motor. The interior is a question of personal taste. 2012 SDV6 - it's missing a couple of cylinders
V6 - spun bearings and crank problems, generally low likelihood compared to the amount of vehicles on the road, but it does happen. I had it happen to me.
The problem with the oil filter is not the location so much as it is possible to put it in incorrectly and still fit the cover, I believe. Doing so is, of course, quickly terminal for the engine.
sergeiicz Member Since: 19 Mar 2020 Location: Caslav Posts: 2 ![]() ![]() |
thank you all!
If you like the updated RRS - the TDV8 was also available in the later version (2010/11) for a while alongside the 3.0 SDV6.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
The most loved the better, the newer the better. And you will not go far wrong whatever the model. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Matt007 Member Since: 16 Feb 2020 Location: Burford Posts: 8 ![]() ![]() |
Matt IIRC (it’s a while since I owned an L320 RRS) you can set the trips (there is a trip A and a trip B) to automatically reset At the end of each journey in the info screen settings. I used to have trip A set to auto reset and the trip B to be what I thought would be the life time for mpg - that was until the car went for its first service and they disconnected the battery to do a software upgrade and both trips were reset......... the L322 FFRR had the same facility too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Goodfella Member Since: 28 Jan 2019 Location: Essex Posts: 4 ![]() ![]() |
I assume 20-25 MPG isn’t on a long motorway run?! Might as well get the 5.0 ![]() |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I've had my TDV8 for 4 years now and overall I get 25.1 mpg. On a couple of runs to Scotland from Sussex 2016 (1390 miles and 1885 miles) I've got 26.15mpg and 27.23mpg respectively. That obviously includes both motorway, on the way up and back, and local roads in Scotland.
Depends how many miles you do. If it's a weekend vehicle, not used for commuting etc., then the petrol is the better option. If you're doing 20k miles a year, the 10mpg difference between the S/C and the TDV8 is going to add up... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Quite right. And my spreadsheet tells me that, on my 9000 miles or so each year, if I had a car that averaged just 15 mpg it'd have cost me an extra £148 per month in fuel. Robin
