Home > Technical > Ran out of diesel |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
Try a search on Disco3.co,uk, there’s a fair few topics on there if you put in run out of fuel or schraeder Joined the X5 45e club
Sat Mar 14 2020 8:29pm |
Start here https://disco4.com/forum/if-fuel-system-ne...uel+system Joined the X5 45e club
Sat Mar 14 2020 8:32pm |
Also look at page 195 of the manual, fuel and refuelling Joined the X5 45e club
Sat Mar 14 2020 8:34pm |
Sat Mar 14 2020 8:36pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
you need to refill with a decent amount (4 litres?)
Sat Mar 14 2020 8:51pm |
Warlowg Member Since: 14 Mar 2020 Location: Wiltshire Posts: 8 |
Thanks guys.ive put two Jerry cans worth in.Shouldnt I get fuel come out the schrader valve if all air is bled out.its still not starting |
Sat Mar 14 2020 8:54pm |
Have you followed that routine? Joined the X5 45e club
Sat Mar 14 2020 8:55pm |
Do I turn the key one or two clicks? Do I repeat the turning key and waiting 30 seconds for 5 minutes |
Sat Mar 14 2020 9:06pm |
Ignition on is with all the dash lights on but not turning it over leaving it there for 5 mins Joined the X5 45e club
Sat Mar 14 2020 9:16pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
When mine ran out (fuel sender unit wiring U/S), it took quite a while. You will need a healthy battery or jump leads. |
Sun Mar 15 2020 12:35pm |
Just had rac come out and he said that he can’t hear the fuel pump.checked fuses and tried some easy start with no joy.still no fuel coming out the schrader valve |
Sun Mar 15 2020 2:26pm |
So I decided to listen for the pump myself because the rac man did it with his own engine running.I could hear the pump running but sounded like it was slurping to get fuel so took two Jerry cans and got 10 litres. That’s now 20litres I’ve put in and after doing what you guys told me too ( turning the key and waiting for 30 seconds) did this 5 times and now I see fuel coming out the schrader valve.turnt the key a few times and it fired up.Thank you all so much I’m very grateful and will not let it get low on fuel again |
Sun Mar 15 2020 4:19pm |
I thought it needed 10 litres
Sun Mar 15 2020 5:11pm |
