![]() | Home > General > Transfer box |
Matt007 Member Since: 16 Feb 2020 Location: Burford Posts: 8 ![]() ![]() |
It’s the 3.6 TDV8 model....... |
A leak from an output flange oil seal isn't that unusual. Cost will depend which one is leaking. The transfer box has to be dropped and split as the flanges are installed from the inside (at least the front one is, anyway). This can require the internals being removed depending on which oil seal is being replaced. It's not a big job but there is a bit of time involved, obviously. It's the same transfer box for all versions. Depending on mileage it could be worth putting a new transfer chain in.
Nice one RRSTDV8 😊
