Home > General > Coolant leak 400 miles from home
PC76
Good morning all,
i drove up to Oban yeaterday for work and my coolant low warning came on aprox four times in 400 miles on my journey. fortuantly i had some water in the boot so used this to top the sysem up.
As i am due to drive back home later today after visting a couple of sites on the Isle of Mull i would like to see if there is anything obvious i an check before i start driving again.
i have searched this forum and noted that the oil cooler (next to the fillter) is sometimes suspect. i have checked for creamy oil and dont appear to have any.
Also, i intend to presure test the system when back home by either jerry rigging a presure cap or purchasing a toolset to complete. just wondering what presure i should be running it up to. (noting the engine should be warm to ensure the thermostat is open)
Thanks
Post #596039 Thu Mar 05 2020 7:44am
Stevepd
I remember an article about a steel into rubber hose down by the thermostat and the hose ran down passenger side of the engine (2.7). They found it just by chance and the steel had corroded on the outside which caused coolant loss.
Worth a look. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #596071 Thu Mar 05 2020 5:02pm
PC76
Thanks steve.. will hopefully have a chance to have a look tomorrow...
Just driving back now and topped it up for the first time just at the head of Loch Lomond so have managed about 70 miles....😳 keeping it below 2k revs ....
Post #596076 Thu Mar 05 2020 5:48pm
PC76
on my way home last night i deared take the car up to 2k reves, the water level dropped very quickly say less than 30miles as i had to pull in to the next servicdes after topping it up.
If i remember does the second turbo kick in around this mark and if so what part of the coolant could be affected.. or do the EGR valves open at this point?
keeping the car at a steady 60 approx 1600 revs it seemd to last 60-90 miles between fill ups....
Thanks
Post #596113 Fri Mar 06 2020 10:40am
PC76
Hi All, i believe i have identified where the leak is coming from. please see the below photo. this is under the Throttle body (sorry corrected) at the top centre of the engine. this was hissing with very fine bubbles when the engine revved.
Has anyone experienced this before and can you please confirm what part/s were replaced in order to fix the issue.
Post #596123 Fri Mar 06 2020 4:55pm
PC76
I think i have identified the part, LR73372 Water connector.
Does anyone know what else is required or advisable to change when swapping this part?
thanks
Post #596132 Fri Mar 06 2020 6:30pm
knwatkins
Thanks
The second turbo kicks in at about 2800rpm.
Glad you got home in the end. Fingers crossed replacing that will solve the problem. Kev
Post #596133 Fri Mar 06 2020 6:41pm
PC76
Please see pic below, the coolant had not spilt out as the system was low already so was already there.
As a precaution and because the part was cheap £26 I have bought the part I highlighted earlier, unfortunately they did not stock the Ring for the oil cooler.
does anyone have experience with the oil cooler failing, and if so would the loss of coolant be a symptom?
Post #596155 Sat Mar 07 2020 12:18pm
PC76
Coolant leak fixed
Update: Leak fixed, no need to swap the o-ring on the oil filter housing as replacing the water connector (LR73372) sorted the problem. The part was held in stock which is telling in it's own right by lrparts.net who are based within 20miles so managed to get there and back with no issues Smile
just need to drain and refill now with the correct mixture of coolant & water..
Post #596321 Tue Mar 10 2020 8:13pm
Eaters
Well done mate. Good to know. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #596333 Wed Mar 11 2020 7:33am
