Home > Technical > Updating ECU via IID
John1311
I have purchased a IID BT which shows on ECU info that most of my ECU's can be updated.
Has anyone done this - is there any benefit and were you charged a lot for the ECU updates ? 2016 Range Rover Sport SDV6 autobiography (MY17)
2017 Range Rover Velar First Edition SDV6
2015 Range Rover Sport Autobiography 4.4
2012 Range Rover Sport SDV6 HSE Luxury Black
Post #596122 Fri Mar 06 2020 4:31pm
knwatkins
The consensus is, don't update unless you are experiencing a problem. It's not like a Windows update on your PC. Kev
Post #596126 Fri Mar 06 2020 5:32pm
Brit Plumber
Agreed, if everything’s working Then don’t update (unless it gives you more functionality). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #596128 Fri Mar 06 2020 5:49pm
John1311
and id agree both both of those if its not like computer firmware updates etc.
How would we know if an ECU update would give enhanced or added functions.
I know I need to update the KVM module so I can add a new key (and am expecting I will get that FOC from GAP) for example. 2016 Range Rover Sport SDV6 autobiography (MY17)
Post #596129 Fri Mar 06 2020 5:56pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
While I understand the "if it ain't broke don't fix it" thoughts, surely there must be an improvement made with a newer firmware version, as in the manufacturer made a fix or improvement even if it did not appear to affect us?
Or why would they bother making a change and presumably applying the latest version to the current production line? 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #596156 Sat Mar 07 2020 12:24pm
Disco_Mikey
JLR are having huge problems with the ICTP, with newer firmware actually making the system worse Laughing
Post #596171 Sat Mar 07 2020 3:47pm
