![]() | Home > In Car Electronics > Using stock amp with aftermarket head unit |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
My issue is the lighter only gives 8v which isn't enough to trigger the relay |
My issue is the lighter only gives 8v which isn't enough to trigger the relay. Not sure why though. |
Nah its because the front cigar lighter is only 8v, the rear is 12v.fml. Is there any other acc cables I can tap into? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
what are you using the lighter wire for ?
The RRS system is more like HEADUNIT > DISPLAY > AMP > TMS > PHONE TMS and PHONE in rear drivers side of car |
Someone already has. I can't remove the glove box either since its snapped my torx bit. Am guessing the wires too thin a gauge for 12v? I don't know what else they might of messed up tbf. |
you shouldn't need any tools.
ah so I can do that, but they've routed it behind the fuse box |
I think my batteries knackered. it only has 6v when the cars off. ill charge it overnight and see if it will stay at 12v but am not hopeful. |
is the battery in your meter ok ?
yeah its a brand new battery.
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Cheers Andy, That throws a curve ball in my logic, but suggests the OEM HU is not functioning 100% as I suspected. I've got a replacement coming so will have to wait and see... Thanks again 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
So, batteries charged, the multimeter says its at 8v so who even knows what that means. Cars started. When I put a fuse in for the lighter the car won't start. Everything just turns itself off? Dafuq
she's all hooked up and working perfectly. thanks for your help gents. my issue was just loose connectors really.
