Home > Maintenance & Modifications > Replacing air struts
ryan_holton
Hi, I have a 2011 Range Rover Sport HSE 3.0L TDV6, I don't have the adaptive air suspension that adjusts itself as you drive, but I'm trying to figure out whether it's worth replacing all of the air struts with height sensors together? I looked online and found that a single air strut is about £400, is it worth replacing them all? I'm at 100,000 miles now
Post #595341 Fri Feb 21 2020 7:36pm
knwatkins
If there's nothing wrong with your struts then they don't need replacing. Same with the height sensors.
If however you have a bouncy ride (worn dampers) or they are leaking (knackered airbag) then the struts will need replacing.
I replaced all four of mine with Dunlop units for just under £700 from memory. They transformed the ride for me. Kev
Post #595342 Fri Feb 21 2020 7:48pm
knwatkins
Also, have a look at your previous post. You have some useful answers..
https://www.rrsport.co.uk/forum/topic54636.html Kev
Post #595343 Fri Feb 21 2020 7:52pm
Duc750
Re: Replacing air struts
You're aware that all air suspenion is active right ?
don't confuse it with active damping that bit is a yes or no but air suspension that constantly adjusts is basically what air suspension is in its most basic form 2012 SDV6 HSE (technically its hers)
2000 D2 TD5 - definitely mine
2005 D3 V8
Metalian Camper trailer for adventures
Post #595344 Fri Feb 21 2020 9:18pm
