Home > Wheels & Tyres > Wheel and tyre question
Cymru001
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi All,
I currently have 275/40 R20 wheels and tyres fitted to the car. My questions are -
Are there any steel wheels available which I cold fit which would then enable me to fit a tyre with a large side wall and use for mud plugging? If so, what are the tyre options? What does everyone feel is a good off road tyre? I've read a lot about the Grabber AT3. Thoughts?
In relation to alloys, what are the smallest rims I could fit? I am thinking of getting a winter wheel/ tyre combo to put on when the temperature drops. I would be using them for tarmac/ on road use especially in the snow so tyre suggestions would also be good!
Thanks.
Post #595279 Thu Feb 20 2020 11:18pm
What do you mean by "mud plugging"? A bit of green lane type stuff or more adventurous axle deep mud? If the former, then the AT3 will be very good. If the latter, then you'll want a dedicated MT type. I'm not sure there's much in the way of MT in the UK in sizes that fit the RRS.
The AT3 will get you around most stuff, to be fair. It's available in 275/40/20.
The smallest rim you can fit to your RRS is 18 inch and that's a specialist aftermarket wheel by Compomotive, the PD1881. That would allow fitting of the BFG ALL TERRAIN T/A KO2 which is probably the best tyre you could fit for off road work.
I run 19 inch rims with 255/55/19 fitted. Have done for a number of years. I have used the AT3 in that size and they're good. I've currently got Pirelli AT+ fitted - just to see what they're like, to be honest - but I think I might go back to the AT3 again.
For winter road use, pick from one of the premium manufacturers and you shouldn't go too far wrong.
https://www.tyrereviews.co.uk/Article/2019...e-Test.htm
I'd be tempted to just run Michelin CrossClimate SUV all year round for road use.
https://www.tyrereviews.co.uk/Article/2019...e-Test.htm 2012 SDV6 - it's missing a couple of cylinders
Post #595294 Fri Feb 21 2020 10:29am
Cymru001
Thanks RRSTDV8,
I was thinking more along the lines of green laning. I've seen some 19" wheels on ebay and I may go for them. Fit some ATs and off I go Very Happy Are they a straight swap or do I need spacers, speedo alterations etc?
I had an FL2 with Pirelli Verde All Seasons which were great. There wasn't anywhere it wouldn't/ couldn't go. Sadly, I haven't found these in 20"
The Michelins look like a good all rounder so may opt for them.
Post #595298 Fri Feb 21 2020 11:12am
Which 19s are they? I believe that some don't fit over the larger brakes fitted to some models. 2012 SDV6 - it's missing a couple of cylinders
Post #595303 Fri Feb 21 2020 12:23pm
Cymru001
These -
https://www.ebay.co.uk/itm/GENUINE-RANGE-R...SwqUleNFYK
Post #595305 Fri Feb 21 2020 12:47pm
Those are for the Full Fat Range Rover, so not sure if they'll fit the brakes on yours.
This type will fit as it's the type I run (and previously ran on my Brembo-equipped TDV8 )
https://www.ebay.co.uk/itm/GENUINE-RANGE-R...SwxwNZ3gck 2012 SDV6 - it's missing a couple of cylinders
Post #595306 Fri Feb 21 2020 12:58pm
Cymru001
That's strong money for something I want to slightly abuse! £1250 before any rubber is more than I want to spend for wheels with rubber!!
Post #595311 Fri Feb 21 2020 1:19pm
I was just using it as a way of identifying the particular wheel design, that's all.
I paid £450 for my set and then bought a couple of others singly over time for spares. 2012 SDV6 - it's missing a couple of cylinders
Post #595318 Fri Feb 21 2020 2:48pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
You can get the Pirelli Verde All Seasons in 275/45/R20 which is a popular size change with folk on here. I probably will go for this option soon at tyre change time and my insurer said it was a no cost change (A-Plan told me it's an insurer informed change with it not being a standard fitment size) 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #595329 Fri Feb 21 2020 4:36pm
Although the Pirelli Verde AS is a LR OEM fit these days, in a smaller size (235/65 R17) it did not perform very well against other all season tyres.
Post #595331 Fri Feb 21 2020 4:53pm
Oldandconfused
Have a look here for wheels idea;
https://www.rrsport.co.uk/forum/topic55694.html
Post #595362 Sat Feb 22 2020 8:14am
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
I'll second the suggestion of 19" OE snowflakes. I've fitted a set for the winter on my TDV8 - pic below
The set of four wheels, decent condition but with trashed summer rubber only cost me £170 on the 'bay. I'm thinking of getting another set to put some AT3s on. I'm not such a fan of the 20" wheels now as the ride is much better with the 19s higher profile tyres.
 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #595374 Sat Feb 22 2020 2:34pm
Stevepd
Do you know what, I’ve put my 19 original V spokes/winters on in Dec and I really like the ride. I’m considering not putting my Supercharged style 20’s on. I’ve got some bush work on the horizon which will make the ride float worthy Thumbs Up my 19’s are ok but if I chose to keep them on they’d need a refurb. Only today we went out and within 5 miles my wife’s asleep. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #595381 Sat Feb 22 2020 3:46pm
insiorc
I'll need to get myself a set of 19" wheels Laughing 13MY Range Rover Sport Autobiography SDV6 - mine
Post #595387 Sat Feb 22 2020 4:39pm
Stevepd
Thumbs Up . It’s normally starts off with bagpuss type yawns, then the tempur travel pillow comes out and she’s as good as gone!. She says it’s this bloody car (in a humorous tone) Mr. Green 2006 2.7 TDV6 HSE in Cairns Blue.
Post #595389 Sat Feb 22 2020 5:12pm
