![]() | Home > General > Tip if you have a puncture L494 |
agree they are Heavy |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
Sticky string ???????????????????????????? |
IanV8 Member Since: 06 Jan 2020 Location: Dunfermline Posts: 60 ![]() ![]() |
No choice for me, no space for a spare wheel. So it will be Mayday.
I know ... they are heavy. I had a full size 21" spare in there and had to take it out a few times. Not to replace a punctured tyre/wheel but for other reasons. I didn't even have the helper strap thing as it was missing in the beginning and I got it from the dealer later
The previous way of storing the spare under the boot in RRS1 and Disco 3/4 left them prone to theft. It was too easy. At that time we used to complain about that design and wondered why didn't they make space for the spare inside the boot like FFRR. This very forum will reveal a lot of frustration if you search for "spare wheel stolen" or something along those lines. I have no reason to defend LR and don't even own one of their products now but just offering some background. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
The inside spare wheel well also allowed LR to design in a clean dry location inside the boot for the suspension compressor that in the previous generation cars was outside under the car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
07MY RRS TDV6 Arctic Frost Aspen Interior |
The underslung wheel was a rubbish design because it was easily stolen, it was also a pain to get out from under the back, unhook the cable, drag it the rest of the way out. Then you have to hook the removed wheel back on and winch it back up whilst easing it back in to place under the back end. Tension required on the cable at all times or it would go wrong and leave you unable to winch in. You get dirty every time. Pig of a job. 2012 SDV6 - it's missing a couple of cylinders
And you have to do most of that just to check the tyre pressure.
That's why I carry a tyre compressor in the RRS under the back seat (along with jump leads, tow rope, strop, fire extinguisher and a few other odds and ends). At least then, if the worst happens and the spare is low I can pump it up before driving away. Also useful if there is a slow puncture - had that before where the tyre looked low, checked and it was down and I saw the screw in the tread. Inflated to suitable pressure and then gentle mile drive to get it fixed. 2012 SDV6 - it's missing a couple of cylinders
Yes having a compressor is a good idea - when I had my flat I was going to just put the strings in but without a means of pumping up there was no point - noting the strings are for emergency use only and you will have to get the tyre repaired properly anyway but I would prefer to do that at my leisure rather than as an urgent action.
Always carry this in the boot just in case.
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
We had our external spare wheel stolen twice on our 2012 RRS (they even took the ‘anti theft’ plate on the second occasion). I wouldn’t want to go back to the external arrangement - but then I’ve never yet had to remove the full size wheel from the internal well on the current one. Carrying a sealant kit for emergencies sounds like a sensible plan. Current: 2020 P400e HSE Dynamic
