Home > Technical > new head unit retained satnav
hairy
United Kingdom 2009 Range Rover Sport TDV8 HSE Zambezi Silver
Just for everyone..... just finished fitted new head unit with reverse cam, I now have DAB radio/DVD and a far better bluetooth hands free system, retained the SATNAV as well
Post #594909 Sat Feb 15 2020 3:00pm
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
I did a similar thing on my D3.
Post #595056 Mon Feb 17 2020 9:55am
hogster
Ireland 2006 Range Rover Sport TDV6 SE Bonatti Grey
What camera did you use and easiest way to wite it in? Does it power off reverse lights and attach where license plates bulbs are?
Post #595101 Mon Feb 17 2020 11:38pm
hairy
used the camera that came with the kit
I used the camera that came with the kit, it is actually very good, works well at night as well. I fitted the camera under the rear spoiler, wiring runs though the wee rubber ducts that are already there, I picked up a power supply from the reverse light.
It was all fairly straight forward just time consuming.
So wiring runs from camera through the wee rubber ducts at the top of the rear hatch, across and down to tail light(reverse) then through the inner panels and under the carpet to beside the drivers seat, then up into the back of the dash.
Takes time and a wee bit fiddly but works great!
[img]http://www.rrsport.co.uk/gallery/albums/userpics/27865/29-712.pdf[/img]
Post #595141 Tue Feb 18 2020 6:20pm
mgrover
am trying to do something similar BUT also have the amp working perfectly via a MOST interface.
Post #595260 Thu Feb 20 2020 7:29pm
