Home > Wheels & Tyres > Tyre Pressures.
joka748
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
Tyre Pressures.
Like others, I've moved from the standard 275/40R20 tyre on my 2012 RRS to Pirelli Verde All Season 275/45R20. For those that have the same tyres, what pressures are you running? I'm using 2.2 in the front and 2.5 in the rear (as per standard). Thanks in advance.
Post #595021 Sun Feb 16 2020 8:58pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
35 PSI front, 38 Back RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #595086 Mon Feb 17 2020 4:59pm
joka748
Thanks Hog. A couple of PSI higher than mine. Did you get to these pressures by experimentation or recommendation?
I ask as I've been mud and snow / winter tyres before and always found the car rock-steady when there's lots of water on the road but find the Verde All Seasons a little skittish.
Post #595214 Wed Feb 19 2020 8:52pm
Hog
Tire pressures are basically the same as 275/40/20.
My experience: 35 and 38 (cold) proved to be good for all types of road incl highway speed, without compromising comfort. It also gives less tire wear.
33 F and 36 R is most of the time a little low, unless you drive in the city and you're the only occupant.
38 F and 42 R is necessary when you got maximum passengers and luggage on board particularly at highway speeds. RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Post #595230 Thu Feb 20 2020 11:42am
