Home > General > Head Rests TV
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Head Rests TV
Guys.
I’m on the look out to change the head rests on my 2013 autobiography so that they have screens in the back for the kids. Will any other model head rests fit my 2013?
Craig ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #594853 Fri Feb 14 2020 4:48pm
Brit Plumber
Disco 4 headrests and I think late freelander headrests are the same but won’t have Autobiography on them. The RSE module will work but has the LR logo rather than RR but this can be configured with SDD if required. The 2012 on FFRR uses the same system but the headrests are different (but I think will still fit as posts are the same distance apart). Same I think for Evoque.
Whatever you go for, you will need the 2012 to 16 style. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #594885 Sat Feb 15 2020 8:59am
McFarTech
Thanks mate. Will keep my eyes posted. ===========================================
Post #594894 Sat Feb 15 2020 10:35am
McFarTech
Would l322 vogue fit? Also I assume a Range Rover sport 2009 l320 head rest won’t fit my 2013 l320? ===========================================
Post #594928 Sat Feb 15 2020 8:08pm
Brit Plumber
I’m not sure if the L322 will fit, they may fit but not sure how they will look.
A 2009 would physically fit ok but the screen is smaller and works on the older system rather than the 2012 on system. 2019 5.0 SC SVA (Current)
Post #594946 Sat Feb 15 2020 10:54pm
McFarTech
Thanks mate. Its this that I had seen.
https://www.ebay.co.uk/itm/Genuine-Land-Ro...SwuM9bpkyh ===========================================
Post #594947 Sat Feb 15 2020 10:58pm
Brit Plumber
I can see that the posts are different and will be a mare to change over. Also the screens are smaller and there’s a good chance won’t work with the later 2012 system. The expensive bit is the screens so your best off buying a ‘kit’ from a breaker. You need a module, 2 headrests with screen, looms, white fire receiver and volumetric alarm censor housing, white fire headphones, remote and if you want, you can put a dual view screen in for the front passenger. 2019 5.0 SC SVA (Current)
Post #594974 Sun Feb 16 2020 8:47am
McFarTech
This sounds expensive. Might need to rethink it ===========================================
Post #594980 Sun Feb 16 2020 9:40am
McFarTech
What other options are there? I’m fine with a tablet style screen connected to the back of the head rest. However what I really want is for the screen to display what’s up front. Eg I pop a dvd in and it play in the back or input the tv on and it shows in the back.
Open to exploring any suggestions on what others have done ===========================================
Post #594987 Sun Feb 16 2020 11:41am
geoffsnook
Check out incartech see what they have do quite a bit of gear for Land Rover Thumbs Up
Post #594991 Sun Feb 16 2020 12:16pm
Brit Plumber
A kit from salvage would set you back approx. £700 with everything you need. Stripping out the interior including carpets takes a few hours but it does give you an excuse to do a deep clean.
I put dual view in at the same time so all passengers could watch the same thing. 2019 5.0 SC SVA (Current)
Post #595055 Mon Feb 17 2020 9:43am
McFarTech
£700 I don’t mind. Just got to find a salvage Range Rover sport. ===========================================
Post #595058 Mon Feb 17 2020 10:02am
geoffsnook
These are on ebay amongst othere may be of no use to you but a quick search
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...item21684a
Post #595083 Mon Feb 17 2020 4:27pm
McFarTech
Would these fit?
https://rover.ebay.com/rover/0/0/0?mpre=ht...4126337867 ===========================================
Post #595458 Sun Feb 23 2020 5:34pm
McFarTech
Censored . They sold before I got a chance to check. Ffs! ===========================================
Post #595459 Sun Feb 23 2020 5:43pm
