Home > General (L494) > RFID (Faraday) Pouch - Failures |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Pressing the button only transmits the signal very briefly and only on press of button whereas with keyless activated it is continuously transmitting. Dramatically increasing likelyhood of signal being intercepted. Besides the person needs to be closeby with recuever/transmitter to pick up signal |
Thu Jan 09 2020 11:49pm |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 251 |
You would think so, however I have tried 3 different cases none have shown any serious wear and tear. The last case is in a landscape format so far easier to see the entire inside of the case and there is absolutely no damage to the lining. On the first two pouches I would put my complete bunch of keys into the pouch and would accept that sharp edges of the other keys MAY have abraded the lining, hence why I only put the LR Key Fob in the latest one, which incidentally is supposed to be a high quality RFID case. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Fri Jan 10 2020 8:32am |
Damo1606 Member Since: 26 Sep 2018 Location: London Posts: 55 |
Best pouch available is from a company called WeShield. You can find them on Facebook. Through is almost like a Kevlar material and will last for many years. You will soon see why this is so good compared to those cheaper leather ones on Amazon. |
Sun Feb 09 2020 11:14am |
I will give it a try: https://www.ebay.co.uk/itm/273105366869 MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
Sun Feb 09 2020 1:37pm |
Mike London Member Since: 22 Jul 2014 Location: Cotswolds Posts: 55 |
I just use some folded tin foil ... works fine 2014 RRS AB Santorini Black |
Wed Feb 12 2020 9:22pm |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
I bought one of these in 2017, holds both keys and still works, I do check every now and then
Thu Feb 13 2020 6:41am |
