Home > For Sale & Wanted > [For Sale] BAS2 RRC Remapping Bluetooth Module
Williamhh
For sale is my BAS RRC 2 Bluetooth module which I bought for my 2010 Range Rover Sport TDV8 in 2015 but am now selling the vehicle in standard specification. It work seamlessly with the BAS App run from an iPhone or iPad to change the engine map on your vehicle but also to run basic diagnostics and fault code reading.
I can highly recommend the map - the car drives noticeably better and the 'tuned' map can easily be swapped with the original map when necessary.
You will need to buy the map itself, specific to your car from Pete at BAS:
https://secure.bellautoservices.co.uk/stor...p-control/
Best to check whether or not your car is compatible directly with him.
I paid £265 for the module and would like to see most of that back as it is essentially brand new.
Thank you
Post #582211 Tue Jun 11 2019 4:43pm
Olismithkent
Hi there, I just bought a 2010 TDV8 and am very interested, do you know if this has the same functionality as the IIDgap tool, or is it a locked down version for Bell? I need the full functions as I will be adding a Locking E-diff and likely some other bits in the future.
Post #583874 Fri Jul 12 2019 12:16pm
Williamhh
Hi, I have asked Pete who developed the tool and the answer is:
"The bas2 rrc tool is engine only functions and does not have full car diagnostics as the IID tool does."
Regards
Will
Post #583879 Fri Jul 12 2019 2:11pm
Olismithkent
Thanks Will, think I am going to go for the full diagnostics options as have other potential needs for it.
Good luck with your sale.
Oli
Post #584017 Mon Jul 15 2019 1:49pm
Williamhh
Nobody keen?
It's a brilliant bit of kit and makes a significant difference to the driving experience of these cars.
Post #586595 Mon Sep 09 2019 12:00pm
Williamhh
Just giving this a little bump.
@bellautos any use to you?
Will
Post #594743 Wed Feb 12 2020 1:49pm
Williamhh
This is still available, I'm open to offers as the car has now gone.
Will
Post #596255 Mon Mar 09 2020 1:27pm
Williamhh
Still for sale
Post #600502 Fri Jun 19 2020 9:16am
Williamhh
Anyone keen for this brilliant bit of kit before it goes in the bin?
Post #604850 Thu Sep 24 2020 9:16am
