Home > General > What to buy? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4992 |
yeah get the 4.2 SC if you can afford 13 MPG |
Mon Feb 10 2020 8:55pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
A £6k RRS is going to be pretty tired, to be honest. Take your time and find one with a huge pile of receipts that show things like suspension bushes having been done, gearbox flushed etc. And be prepared for bills as things will doubtless need doing to it. 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 10 2020 9:00pm |
Amgmatt Member Since: 10 Feb 2020 Location: London Posts: 14 |
Thanks for taking the time to reply. What are the costly repairs for a rrs? Have heard about air suspension etc. But i assume consumables like brakes and tyres are expensive anyway! |
Mon Feb 10 2020 9:53pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
Hi i bought mine not long ago and milage use probably a lot less than most odd popping to shops and taking dogs to local park maybe 2k in miles a year in a 2007 2.7 Hse it had 128k mile on the clock 1 owner from new full FSH just under 7k so far bar service costs and looking to get gearbox flush no more expense than any other motor i have owned, i do live in my works van a transit custom i bought from new 4 years ago which has now 250k miles on the clock and with that have the oil changed at half what the manufacturer recommends no problems so far, bar wear and tear which to be far is very little.
Mon Feb 10 2020 10:11pm |
Hi mate thanks for the reply.
Tue Feb 11 2020 5:53am |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
you can always get a remap to at least 250 horses Joined the X5 45e club
Tue Feb 11 2020 6:42am |
There not fast fast but surprisingly quick when you put your foot down, saying that if you want quick go for the V8 SC and the noise is better if don't mind the more frequent trips to the petrol station. i get about 18-20 mpg out of the V6, i believe the V8 SC can be under 10 mpg. |
Tue Feb 11 2020 6:46am |
The 2.7 is slow, there's no other word for it. If you're happy to waft aling then it's fine. If you want a bit of poke for the occasional blast or for easy overtaking, then it's lacking.
Tue Feb 11 2020 7:46am |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 |
This doesn’t sound like it’s going to end well.
Tue Feb 11 2020 7:57am |
Thanks all for your replys, i knew id not get anything newer than perhaps an 07 plate
Tue Feb 11 2020 3:43pm |
are most of them petrol or diesel ? |
Tue Feb 11 2020 5:13pm |
Keep your eyes peeled on this forum and one will likely turn up followed by a dozen more. The petrols appear to be a lot more forgiving and with the exception of fuel, are cheaper to run. My last service on a 5.0 SC was £200 cheaper than the quoted (independent) cost of the TDV8 (he based his estimate on the TDV8 as he doesn’t see many petrols). I then spent that on replacing the rear brake lines. 2019 5.0 SC SVA (Current)
Tue Feb 11 2020 6:04pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Get petrol for reasons above and your low mileage
Tue Feb 11 2020 6:13pm |
This has to be the most active forum ive ever been a part of! 😀
Tue Feb 11 2020 7:35pm |
