![]() | Home > General (L494) > Dynamic response |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
If you have Terrain Response 2 (the auto on the Terrain Response) and leave it in auto mode, it should do it for you. I'd probably still select snow/grass mode manually to make sure the system was really working on that setting. Make use of low range too if required. 2012 SDV6 - it's missing a couple of cylinders
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
Dynamic response is for when you want to push on....it stiffens the damper settings and changes the fuel mapping to make the engine more responsive.... think twisty windy a roads!
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
As above |
