Home > Technical > Rear Lights
JB-johnnyboy
United Kingdom 2012 Range Rover Sport SDV6 HSE Fuji White
Rear Lights
Good day boys and girls
2012 RRSport owner, I have a problem with the drivers side rear brake light (LED) cluster. Drivers side does not light up when brake applied, i have removed the cluster and plugged in to passenger side and works fine. after long journeys the light tends to work on occasion, but when car left over night the brake light does not work again..
Is there anyone who can shed some light on this very annoying electrical issue..... Thanks in advance
Post #594556 Sat Feb 08 2020 4:35pm
Eskimo
Silly question but if you plug the passenger light into the drivers side does that still work ok?
If not then I'm guessing that one of the pins in the connector is at fault/dirty/corroded. It might be worth getting some electrical contact/switch cleaner and give the connector a bit of a clean out......however dont use WD40 as it can leave a film over the pins which can give problems later.
If you can't get switch/contact cleaner then IPA (not the alcoholic variety Wink Laughing Laughing Laughing ) might help to. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
1999 Discovery 4.0 V8 (Gone but not forgotten)
1997 Range Rover 3.5 V8 (Long gone now)
1966 Series II SWB with RR 3.5 V8 (Never finished, now sold)
Post #594566 Sat Feb 08 2020 9:05pm
JB-johnnyboy
Hi Eskimo
I have tried passenger cluster in the drivers side and that doesn't work, i have also tried a brand new one as well that also doesn't work. Also wired in a different connector on the car side to receive the cluster, i think the problem seems to be nearer the electric source in the car some where!!!!!!!!
Would it be possible to tap in to the other brake lights and power the none working one that way???????
As there is no towing sockets fitted there is options surely???? other than that i haven't got a clue and its bugging the Censored out of me!!!!!!
Thanks for your previous reply
Post #594584 Sun Feb 09 2020 11:25am
Brit Plumber
Is it just the brake light? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #594628 Mon Feb 10 2020 1:38pm
JB-johnnyboy
Hi Brit Plumber
Yes just the brake light....All other lights work fine..
Post #594644 Mon Feb 10 2020 3:09pm
Eskimo
I'm guessing of you're handy with a soldering iron then you could possibly splice into the passenger side brake light cable.
This of course still assumes that the connector itself is in good order and not the problem. 2006 RRS HSE 2.7 TDV6 (The Baby one as I keep being told)
Post #595119 Tue Feb 18 2020 1:15pm
