![]() | Home > General (L494) > Deployable side step problem |
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
Happens to me every now and then. I find that disabling the system then turning it back on again solves the issue, either that or manually deploying them occasionally also does the trick. Ferrari F430 Spider F1
crasher73 Member Since: 31 Jan 2020 Location: Peterborough Posts: 23 ![]() ![]() |
Cheers for the reply. Having only just got the car I've no idea how to do either of these things, is it straightforward? |
It's in your menu chap:
Cool, cheers mate |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 310 ![]() ![]() |
Mine have had a mind of their own from new, I sometimes have to lift suspension to off road full height & clean away leaves to get them to work again, there are supposedly sensors fitted so if you park to close to a high kerb etc they don’t come out & damage themselves, I think leaves, twigs etc that end up under there must give the sensors false readings.
