Home > Technical > non starting? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
Try swapping the relay marked SM in the box Under the bonnet |
Fri Feb 07 2020 8:31pm |
hairy Member Since: 02 Feb 2020 Location: aberdeen Posts: 31 |
thanks will give it try in the morning. |
Fri Feb 07 2020 10:04pm |
well swapped the relay this morning and it made no difference, anyone else got any ideas? |
Sat Feb 08 2020 8:40am |
H Member Since: 17 Nov 2017 Location: Rushden Posts: 28 |
Do you let the glow plug light go out, I had this problem regards chris |
Sat Feb 08 2020 9:44am |
yeah I always wait until the light goes out, but this happens hot or cold so cant be the glow plugs.
Sat Feb 08 2020 11:03am |
check the battery connections.
Sat Feb 08 2020 3:19pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
How did you check the battery, voltage under load or off load? If not already done, have someone check the battery volts while you try to start it, it should hopefully stay above 9.6V - use a meter direct across the battery terminals. Just checking battery volts without load tells very little. 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Sat Feb 08 2020 4:19pm |
checked battery both under load and no load, all ok. I will check the connection on the wing under the battery today weather permitting.
Sun Feb 09 2020 7:09am |
removed the battery and checked the connection and all was ok, so I guess now the only thing left is the starter motor? |
Sun Feb 09 2020 6:54pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Or, have the starting circuit checked, before throwing parts at it |
Sun Feb 09 2020 8:24pm |
UPdate****well finally got under the car and the starter is dead... replaced with new and all ok now. |
Sat Mar 14 2020 4:24pm |
Robs_2007_sport_hse Member Since: 12 Mar 2020 Location: Devon Posts: 5 |
Some times its a bad connection on the starter motor just removing the contacts and cleaning can often cure it.. Bet you had fun changing that starter motor |
Sun Mar 15 2020 8:03am |
it was an absolute pain in the butt... but changed now and all ok, hopefully I dont have to do that again soon!
Sun Mar 15 2020 8:56am |
