Home > Maintenance & Modifications > L320 Servicing at 12 years old and 93,000 miles |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1538 |
My car's about to go to my trusted indie for its annual service. Had a B service done last year and so it's a A service this time. However bearing in mind its age and miles, have any of your guys/gals any thoughts on additional things I should ask them to check or do - minor or major?
Tue Feb 04 2020 1:42pm |
Robin
Tue Feb 04 2020 5:47pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
If you have had your front diff oil and gearbox flushed recently, keep them as is.
Tue Feb 04 2020 7:03pm |
Thanks Kev. That all sounds eminently sensible. I had my rear dampers done in 2018 but might ask them to look at the fronts.
Wed Feb 05 2020 8:30am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I found the service schedule and the only thing not mentioned above is the flexible brake hoses need changing ever 6 years. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Feb 05 2020 9:01am |
Great - Thanks Stevepd. Robin
Wed Feb 05 2020 9:04am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Neither of my RRS have had the flexible brake lines changed at 6 years. I've mentioned this and the response is that they are checked over each service and changed if they are deemed to be needing it. This doesn't seem to be unreasonable. 2012 SDV6 - it's missing a couple of cylinders
Wed Feb 05 2020 10:11am |
“Neither of my RRS have had the flexible brake lines changed at 6 years. I've mentioned this and the response is that they are checked over each service and changed if they are deemed to be needing it. This doesn't seem to be unreasonable“
Wed Feb 05 2020 10:18am |
