Home > Technical > Folding mirrors |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4991 |
Powerfold mirrors were a option on a SE so you may not have them fitted.
Mon Feb 03 2020 9:31pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4975 |
Not in Great Britain |
Mon Feb 03 2020 10:04pm |
They were a option on the SE in the UK.
Mon Feb 03 2020 10:20pm |
TIG1591 Member Since: 02 Feb 2020 Location: Derbyshire Posts: 3 |
Thanks Col as I expected😏 |
Mon Feb 03 2020 10:46pm |
As they were a option you may be able to retro fit and activate in the CCF files if you wanted to, but would need to check if the wiring is there in the door first, rather than buying mirrors then trying.
Mon Feb 03 2020 10:59pm |
Odd I thought the early ones 2005 it were standard across the range.
Mon Feb 03 2020 11:12pm |
Virtually everything now is a option which used to be standard so L/R can charge even more for their over priced products and gimmicks.
Mon Feb 03 2020 11:19pm |
I think the powerfold is only available with memory seat perhaps because of the looms having extra wiring for the mirror memory and dip in reverse. 2019 5.0 SC SVA (Current)
Tue Feb 04 2020 11:11pm |
Generaly I think if something is only available with something else it will say in the price list (only available with so and so pack) or something to that effect, however the powerfold mirrors are listed as a option on their own in the old 10-11 pricelist, so the wiring may well be there.
Wed Feb 05 2020 3:12am |
I think you’re right Col, it appears it’s only a little wire from the door module to the mirror, the power fold motor and a CCF edit. Amazing why it was never standard equipment considering the motors won’t be expensive to buy (although LR probably want to charge triple the cost).
Wed Feb 05 2020 10:39pm |
70 mph. That looks a mistake.
Thu Feb 06 2020 11:49am |
Yeah, say's stationary or less than 20km/h or 12mph in the owners handbook.
Thu Feb 06 2020 8:08pm |
