![]() | Home > General (L494) > Front pad change with Brembo |
https://ebcbrakesdirect.com/automotive/partno/dp32064c
My OCD hasn't let me use anything other than Ceratec on my rebuild for, quite literally, everything ![]() If the pins and springs come out, I'll reuse them,and refit with a smear of ceramic on them to aid future work But I always have a set on the shelf, just incase they don't come out ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5033 ![]() ![]() ![]() |
Andy, this is where I got just the Redstuff pads from for my RRS1 S/C if it's of any use, as they are the same pads as the 6 pot Brembos on the RRS2, got the rears there as well but obviously they are not the same as the RRS2, redstuff are the only pads I found that shut up that dammed annoying squeal the S/C's suffer from. They even shipped them to NZ for me. https://www.motorbling.com/products/5b87d6...t-Road-Pad Cheers Col |
Thanks for the link Col,I’m only wanting the low dust pads for the front as the rears aren’t too bad for the dust. Andy.
You'd be surprised |
In that case then I’ll do both fronts & rears.Its now which discs do I use as Brembo are a decent price on Autodoc £53.10 for rears & £50.94 for the fronts.The only problem with the Brembo’s is every time I wash the car this discs end up with a rust coating on them & that’s why I was going to for the EBC hopefully they don’t get the rust coating after washing. Andy.
I've used Britpart drilled and grooved discs. Zinc coated to prevent rust build up, which I've also painted with HT paint, to hide the bling |
Have you got link for them please Mike,as I’m going to get them ordered this week & hopefully fitted next Friday if I’m not too busy,EBC haven’t got the front red stuff pads in stock but these have that col posted the link & cheaper than EBC,I just need to find the red stuff for the rears now.
The only rears I can find are at the same place as the fronts but these are for the L320,do these fit the L494 Mike.?
RRSporter Member Since: 08 Nov 2012 Location: UK Posts: 61 ![]() |
Rears are definitely changed on l494 as it uses the main pad for handbrake.
Thanks for that RRSporter,I’ve been searching all afternoon for the rears,I even searched eBay but couldn’t find them,I’ll now get everything ordered ready to fit. Andy.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 915 ![]() ![]() |
Spray on Bilt Hammer Atom Mac to prevent rusting after washing |
Lindab,I keep meaning to purchase that as I have loads of BH cleaning products.infact I’ve just used the last of my BHAW today so I need to order more & I’ll get some atomac at the same time. Andy.
Well managed to get all 4 discs drilled & grooved plus ceramic low dust pads from a local company that repairs & services LR's,the discs are from Britpart that DM recommended.All in for £310 plus vat. Andy.
