Home > General > RRS ownership is a slippery slope.. |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
No sooner am I into a reasonable condition TDV8, and have finally realised that I do actually gel with the car and enjoy driving it (having fixed a few of its original faults) and knowing how much better it could be with the suspension properly sorted..
Fri Jan 31 2020 3:13pm |
Once you’ve driven the SC you will ignore the more frequent visits to the petrol station. 2019 5.0 SC SVA (Current)
Sat Feb 01 2020 11:15am |
You are both right, I'm sure..
Tue Feb 04 2020 7:59am |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
I went from
Tue Feb 04 2020 8:39pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Is the tank bigger on the v8 then? I get around 410 - 430 miles out of a tank on the v6. Kev
Tue Feb 04 2020 8:51pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5024 |
84 litres diesel, 88 petrol according to h/book. This is what mine does if you believe the lie-o-meter on the dash.
Tue Feb 04 2020 9:22pm |
What Col has failed to mention here, is that to get his displayed MPG as good as it is, he turned his engine off to save fuel. Sneaky! 2019 5.0 SC SVA (Current)
Tue Feb 04 2020 10:50pm |
Blast, I hoped nobody would notice as I didn't like to show it's only 3.6 mpg when the engine is running in case nobody believed me it was that good on fuel.
Tue Feb 04 2020 10:56pm |
J.Prezes Member Since: 12 Nov 2018 Location: Somewhere Posts: 9 |
Mine gets roughly 10 UK MPG in city driving as low end torque accelerations are quite fun BUT if you step on (you get even lower MPG, which my Lie-ometer doesn't seem to always notice, but i certainly do) it you can see the fuel level dropping. Putting it into dynamic mode "changes throttle response" which, when it comes to fuel economy has only got one effect similar to drilling a hole in the tank. Then the fuel just disappears. The flip side is the amount of points I get on BP petrol stations the in Poland |
Fri Feb 07 2020 12:42pm |
I manged to collect points with mine but they were not from a petrol station.
Fri Feb 07 2020 9:09pm |
