![]() | Home > Faults & Fixes > Tdv8 2007 cant build touque in 2nd gear |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
You could start with checking the fluid level. The engine needs to be running when you do it. Joe |
Terryok Member Since: 06 Jul 2019 Location: Kent Posts: 24 ![]() ![]() ![]() |
Thank you will check |
