![]() | Home > Technical > 2011 Sport Restricted Performance |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
similar to mine which turned out to be the turbo actuator, which I had replaced. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
SportHSE Member Since: 21 Jan 2020 Location: England Posts: 3 ![]() ![]() ![]() |
Thanks for the response! Was that a body off job or is it accessible? |
OvalAutos Member Since: 02 Jan 2019 Location: Cradley Heath Posts: 130 ![]() ![]() |
Common fault for this is the vacuum reservoir not properly connected. You'll find it under the airbox where the top intercooler pipe connects to the engine. Joe |
When I had the actuator done (in France) at dealers, it cost me about 1,600 euros and I think it was about 4 hours labour charged so no body off. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Coincidentally I got my ear in the engine bay a couple hours ago and thought I heard a hissing. Knowing that the valve on the turbo is vacuum operated I stripped the intercooler pipe and the housing (before the throttle body) off are sure enough, the pipe had somehow dislodged. Road tested and it runs beautifully. I then come in to see what you've written. You were bang on. Thank you. |
The codes P22D3 turbocharger inlet valve stuck open and P22CF turbocharger Inlet valve control circuit have caught out some people into thinking they need to replace the secondary turbo at great expense. We've had cars in where the turbo has been changed by another garage (turbo experts), but the problem still persists |
