Home > Technical > Adaptive dynamics & Suspension fault
Chrissyh77
Hi all looking for some help with my 2012 SDV6 RRS.
I got two faults come up on the dash saying Adaptive dynamics fault and Suspension Fault.
Put this on my my JLR diagnostics and it is not showing any faults in the system.
Any help would be much appreciated.
Cheers Very Happy
Post #593417 Fri Jan 17 2020 2:42pm
Disco_Mikey
What diagnostic tool are you using?
Post #593440 Fri Jan 17 2020 8:37pm
Dave B
When I first got mine I got the same plus 'Restricted Performance' after parking on long wet grass.
By stopping, switching off and restarting, all faults went away.
The next time this happened was in freezing fog.
In both cases only when speed was 70mph or more.
Although nothing ever happened in the rain, damp air and speed were the links.
My son suggested these faults were connected to the ABS system, as this does more than just the brakes.
He was right, one rear ABS sensor had the insulation broken near the caliper, not the wire, just the insulation.
Given these are insulated like the old HT Ignition leads, we took the view signals were being tracked to earth.
Anyway, changed both rears and never had the problem again. 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #593443 Fri Jan 17 2020 8:54pm
Chrissyh77
Hi thanks for the reply’s I am using British diagnostics versions of SDD disco mikey.
Thanks for the advice Dave I will have a look into that just a bit of a weird one as it is not bringing up any codes.
I am also getting the restricted performance code now just checked.
I have put the laptop back on and I have a U043A-68 invalid data received from the suspension control module B.
Post #593445 Fri Jan 17 2020 9:18pm
Disco_Mikey
This is the problem with cloned diagnostic kit, it just can't be trusted to report back the correct information
Post #593455 Fri Jan 17 2020 10:57pm
Chrissyh77
That is very true that mate.
These are the faults I am getting so might get a look at that height sensor.
Post #593513 Sun Jan 19 2020 6:24pm
