Home > Faults & Fixes > No power below 2500rpm |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 |
Wild guess, but could be EGR valves.......
Thu Jan 16 2020 11:14pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1173 |
has it had a turbo recon job in the past?
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Fri Jan 17 2020 6:09am |
Timo Member Since: 15 May 2016 Location: Lancashire Posts: 36 |
It’s a 2.7, it also has an engine warning light on.
Fri Jan 17 2020 7:41am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
The intercooler hoses delaminate/split and restrict airflow. Fairly cheap and easy to replace. I would consider that first. Many owners replace them with silicone hoses for longevity. I think there are 3, but it's usually the big one at the front and top of the engine. |
Fri Jan 17 2020 2:52pm |
Dennis V Baldwin Member Since: 05 May 2015 Location: East Grinstead Posts: 13 |
if it smokes like a gooden at start up its EGRs!
Fri Feb 26 2021 10:39am |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
I had that last year, lucky it was just the long turbo hose cheap and easily to change. |
Fri Feb 26 2021 12:06pm |
