Home > Technical > Passenger Door Not Unlocking Unless Using Keyless Entry
Irving
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Sumatra Black
So i just purchased a RRS yesterday and love it. However, the passenger door doesn't unlock with all the others. I dont think its a single/global access issue as all the other doors unlock when you unlock the car using the key fob.
However, if you approach the door with the key it does unlock and open. So yeah.. I am a bit confused because it doesnt seem to be the locking motor, nor a global opening issue.
Any ideas are gratefully received. Hopefully its something simple that I am stupidly missing...
Post #593338 Wed Jan 15 2020 5:22pm
Britishlion
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
I have the same - any help would be great
Post #593412 Fri Jan 17 2020 1:14pm
Irving
INteresting... the exact same thing with the keyless entry being ok but remote unlock not working for one door?
Post #593414 Fri Jan 17 2020 1:29pm
Bigbore
England 2012 Range Rover Sport SDV6 HSE Orkney Grey
Ditto that ✔️ RRS SDV6 HSE Orkney Grey,Premium Ebony Black leather,MY12 Autobiography Exterior Design Pack,22"Diamond Turned Rotor Alloys,interior LED's/Number plate,boot LED's x 2,rear entertainment,HD Dash cam,ALIVE Remap,Bumper DRL's
Post #593561 Tue Jan 21 2020 5:32am
ptaroni
Anybody sort this? I have exactly the same issue ...Thanks
Post #603212 Wed Aug 12 2020 9:00pm
gogsy1956
I'm reading this with anticipation as mine has done this a few times lately,, only the front passenger door is affected. Maybe it's coincidence but when the has happened I've had a suspension fault flash up when I turn the ignition on,, or sometimes just prior to turning off. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #603218 Thu Aug 13 2020 8:32am
mrluke
Re: Passenger Door Not Unlocking Unless Using Keyless Entry
Do you have a scan tool ? like SSD software. Mine flags up in there.
My rears sometimes fail to open using the keyless , but normally work ok with the fob.
Mine is a motor issue .
Post #603221 Thu Aug 13 2020 8:48am
Had a similar issue recently with o/s rear door would always lock but 50/50 if it unlocked, new lock/latch unit sorted it, not uncommon for different door ones to fail.
Post #603225 Thu Aug 13 2020 9:11am
