Home > General (L494) > Failed Regens
samd
Failed Regens
If you permanently select that fairy tale of the dashboard (aka Instantaneous mpg) and lift off throttle to check it's reading 99** just before stopping at your destination, would it eliminate failed regens please?
**provided keep engine running if readings less than 99.
Post #593094 Fri Jan 10 2020 10:26am
Ash3
Interesting question...if a regen uses additional fuel and mpg is partly calculated by amount of fuel being injected....hmm
Post #593119 Fri Jan 10 2020 6:21pm
RRT
Watching.....
If I knew a regen was required or happening then generally I would extend my journey to include a fast run to promote/enhance that regen MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green)
Post #593121 Fri Jan 10 2020 6:33pm
harisson
Switzerland
Hello all
I have heard from a Discovery driver that the consumption will not fall to zero if a regen is ongoing. I am checking that point often but couldn't catch such situation..
Harisson Range Rover Sport HST D350
Post #593122 Fri Jan 10 2020 6:35pm
Ash3
Did he not see reduction in the mpg ie from 99 to say 95??
What about revs??
Lo5s ppl say idle rev speed goes up when regen is taking place??
By how much? Is it noticeable? Ie from appeox 750 revs to say over 800rpm?
Post #593125 Fri Jan 10 2020 8:00pm
