![]() | Home > Faults & Fixes > Engine system fault? |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
similar symptoms to mine which turned out to be turbo actuator but mine is a 2010 facelift 3.0. Need to get diagnostics readings done to find out the problem. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Ziceman Member Since: 08 Nov 2018 Location: Northern Ireland Posts: 18 ![]() ![]() |
Your right my icarsoft diagnostic tool is not telling me anything tbh, will book it in. Bought the yoke 2½ years ago all was fantastic loved the drive then November onwards it's been Replacing ACE pipes then it was the fuel pump in December and straight after getting vehicle I've had this menacing error. Had 2 new Turbos fitted march 2018.
These cars certainly do put immense pressure on marital relations and mental scars on us every time a dash board light comes on followed by "what now". I did put posts on about my issues with the codes that I was getting for the actuator which if you can't find I will check iwhen you get yours done |
Godders I've been looking into the actuator since you mentioned it and all symptoms related to my problem.
My car is the facelift 3.0 and the actuators are different between the two cars, sorry my fault for not pointing that out. Glad you got it sorted and enjoy the car until the next test.
