Home > Faults & Fixes > Rear heated screen
JohnBlueSport
United Kingdom 2007 Range Rover Sport TDV6 S Buckingham Blue
Rear heated screen
Advice needed, heated rear screen on my 2007 2.7 RRS not working. Switch, fuse, relay and heater element all ok. Where to check next? Thanks
Post #592831 Sun Jan 05 2020 12:10pm
Ziceman
Have you checked contacts behind rear spoiler as I've read alot about this being cause of bad connection.
Instructions on how to remove rear spoiler.
https://youtu.be/uYh-dQYEimY
Post #592839 Sun Jan 05 2020 2:34pm
PC76
Are you getting voltage to the connector for the screen?
Post #592840 Sun Jan 05 2020 2:34pm
Try this thread:
https://www.rrsport.co.uk/forum/topic29082...ted+screen
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #592842 Sun Jan 05 2020 2:42pm
knwatkins
As above. It's likely to be the connector under the spoiler. I had the same problem in 2018. I chopped the connector off and hard soldered the wires together. No connector, no problem. Kev
Post #592846 Sun Jan 05 2020 3:59pm
JohnBlueSport
Thanks guys for advice, job for drier day
Post #592847 Sun Jan 05 2020 4:02pm
