Home > General (L494) > Alternative tire sizes |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
This site might help you in your deliberations
Sat Dec 28 2019 9:30am |
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 |
I don’t see why the car would throw an error code. It won’t know what size wheels or tyres it has fitted
Sat Dec 28 2019 7:36pm |
Estrace Member Since: 24 Sep 2019 Location: AIGUES VIVES 30670 Posts: 15 |
wheel-size.com is even better because it gives all OEMstandard tires sizes for all JLR models and gives proper alternatives based not only on diameter or circumference but it takes also into account rim width and offset (very important) as well as scrub radius (very important also), fender clearance, wheel well clearance and suspension clearance so that you are sure that your alternative tire is not going to spoil completely your car handling and safety
Sun Dec 29 2019 3:35pm |
Just to support Estrace's comments, be very careful about offset as this can really screw you up if you get it wrong. (Bitter personal experience). Especially with Brembo brakes
Sun Dec 29 2019 4:36pm |
Jjvd21 Member Since: 20 Dec 2011 Location: Chicago Posts: 241 |
Thanks for the replies. I'm aware that with different wheels you need to be concerned with offset. I'm just surprised you could run tires that are 2%+ larger or smaller than what is recommended without error codes or other problems. I'm skeptical that it wouldn't cause issues. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Mon Dec 30 2019 2:27am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
You'll only get errors thrown up if tyres are mismatched because that will make the systems think the vehicle is constantly slipping, sliding etc.
Mon Dec 30 2019 9:12am |
I'm with Coedlan here. If you cover off the physical issues with regard to fouling bodywork, brakes etc. then the car should not have a problem except that it will affect the speedo reading and maybe the cruise control. On mine with standard 275 40 R20 tyres, the speedo is near enough bang on but the cruise control is 3-4 mph out. So for 40mph I need to set cruise at 43mph. At 70mph cruise needs to be at around 75mph. Not a problem in practice. The electronics will look for variances between the revolutions of each wheel and so as long as you have the same size tyres and wheels on all four corners, they'll be fine. I'm not aware of any monitoring of the revolutions at the wheel when compared to revolutions of the engine on the RRS although others here may know more. I have to admit not being totally on board with how the electronics understands when one wheel is spinning when others are not (when off road say). I thought it was comparing revolutions of each wheel - perhaps someone can enlighten me as to what sensors are involved? PS - RRSTDV8 has beaten me to it - so hope this adds to that comment Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Mon Dec 30 2019 9:30am |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Not sure about LR products, but AUDI uses the ABS sensors to determine if any wheel(s) are rotating at different speeds for tyre pressure monitoring and other warnings. 2010 3.6 TDV8 HSE (Gone)
Mon Dec 30 2019 9:40am |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 |
I have run 275/55/20 Pirelli Scorpions on my Sport with no problems. Speedo shows 102 at a real 100kph. With standard 255/55/20s showed 105 at a real 100kph. The larger tyre's circumference is 2.9% larger than the standard one. There was no fouling of bodywork. Brakes are not affected by tyre size only wheel size.
Mon Dec 30 2019 11:39pm |
I can confirm that running 285/45r22 is not a problem 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Sat Jan 08 2022 10:12pm |
BlueHorizonUK Member Since: 09 Dec 2019 Location: Hertfordshire Posts: 9 |
Can I ask a question please.
Tue Nov 14 2023 1:02pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1175 |
it'll be fine --
Tue Nov 14 2023 1:05pm |
Do 295s even fit on stardard rims? --
Thu Nov 16 2023 8:02am |
No, I believe 10” rims are the minimum. 2020 SVR / R.I.P. 2019 SVR / 2016 D4 Landmark / 2005 D3 HSE |
Thu Nov 16 2023 11:55am |
