Home > General > Ham radio operators ?
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Good morning to all, had the 2012 sport for a month or two now so time to had a few extras. I was thinking of putting the ft8900 in the car but told to watch out for ecu and rf problems and was wondering if anyone else has had problems?.
Also where and how are you mounting your antennas, I currently have no rails or roof bars on the roof.
Any help appreciated, regards Andy.
Post #592147 Sat Dec 21 2019 8:08am
Estrace
France
I have a 2019 RRS SDV6 and I installed an Icom IC7100 with the usual precautions, direct power from the car battery terminals, screened cables, Automatic HF antena tuner, good grounding, plenty of capacitors and ferrite tores, quality coax and antennas, ect ect... and so far no problems with the car electronics when transmitting in HF,VHF or UHF and no QRM from the car electronics, except for some slight noise on some HF low bands (but nothing notable on 10 or 6 meters) when the engine is running, probably comming from the alternator or maybe its regulator
Consequently I think you can give a try to your FT8900 on your RRS, you should not have problems providing the installation is correct because your TX has less power than mine on HF but keep in mind it has more power than mine on VHF AND UHF and I have checked the effect of VHF AND UHF transmission with only 25 watts max and you have 50 watts, it can make real difference
Nevetheless, it is worth a try
Best 73´s from YC6WDB
Post #592334 Tue Dec 24 2019 2:32pm
Estrace
France
Regarding antennas mounting, I mounted them on a roof bar, the UHF/VHF antenna is fed by coax, placed in the middle of the car roof which acts as a ground plane and the HFantenna is on the side, close to the edge of the roof and fed as a long wire with an automatic antenna tuner located in the car boot
My TX like yours has a detachable front so I installed the TX itself in the boot close to the antenna tuner and the detachable front in the glove compartment
Passing all the interconnecting wires cleanly is quite a chalenge but not more than for any mobile installation on any car
73´s DE YC6WDB
Post #592336 Tue Dec 24 2019 2:50pm
Tyrefitter
I’m no pro radio ham operator but I do have a 10metre radio I use to use when I was truck driving,I cannot remember which radio it is but I still have it at work.Years ago when cb was the in thing I’ve had the cobra’s Lincoln’s & many more. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #592337 Tue Dec 24 2019 5:00pm
Tyrefitter
It’s just come back to me,,mines a Magnum Deltaforce 10 metre radio. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #592341 Tue Dec 24 2019 7:38pm
andyslandy
Thanks for the replies guys, think I will just give it a go and see what happens. Tyrefitter what a list of radios I loved the Lincoln and must admit to keep looking at the new version at Knight's across in Kirton on Lindsay.
Post #592361 Thu Dec 26 2019 7:03am
Tyrefitter
Knights know their stuff when it come to radios,ive been there a few time,I wasn’t sure wether they were still on the go. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #592362 Thu Dec 26 2019 8:03am
andyslandy
I think the phrase "until the cows come home" spring to mind, I think like you and really hope so.
Post #592407 Fri Dec 27 2019 2:24pm
