Home > In Car Electronics > Internal accessories power socket
Guitaryellow
England 2012 Range Rover Sport SDV6 HSE Lux Santorini Black
Hi
Can someone tell me if the power sockets are live all the time? Or do they go off with the ignition?
Refards
Post #592356 Wed Dec 25 2019 10:03pm
I'm sure they power down a short time after ignition is switched off, If you do a search I do vaguely recall a post where someone has modified them to be live all the time.
Post #592357 Wed Dec 25 2019 11:00pm
garrycol
Australia
They go on and off with the ignition. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #592359 Wed Dec 25 2019 11:39pm
Had a quick look to see what mine actualy did, they power up by opening the door but have to turn ignition on or they will power down again after couple of mins. switch the ignition off and they power down after two/three mins. if you turn the ignition off and lock the doors they power down straight away.
Post #592360 Thu Dec 26 2019 3:31am
derekmines
Yep, as noted above they power down with ignition...
I'm in the process of adding an independently switched permanently live feed, will do a post on here when I actually install it to the car.
Post #592818 Sun Jan 05 2020 10:36am
knwatkins
There are several permanent live unused fuses in the internal fusebox under behind the glovebox. Fuses 18, 28, 29 and 33. Kev
Post #592848 Sun Jan 05 2020 4:05pm
derekmines
That's really useful to know, cheers.
Is that fusebox accessible without removing half the dash / glovebox?
Post #592849 Sun Jan 05 2020 4:09pm
knwatkins
It certainly is derek. Just open the glovebox, push the stays inboard and the glovebox will hinge down into the footwell exposing the fusebox.
 Kev
Post #592850 Sun Jan 05 2020 4:17pm
derekmines
Awesome news... I can't tell from the pics, are they mini blade fuses or standard sized ones?
I'll get a tap ordered as soon as I know!
Post #592876 Sun Jan 05 2020 7:55pm
denny111
Hi
They are mini
Post #593010 Wed Jan 08 2020 9:46am
derekmines
Thanks for this, the tap has now arrived so I shall see about doing this project over the weekend.
Post #593095 Fri Jan 10 2020 11:20am
derekmines
Glovebox disassembled as noted, next job is to find a route for the power cable from the fusebox area to to driver's side... this look as though it might be entertaining!
Post #593321 Wed Jan 15 2020 12:10pm
