Home > General > L405 L495 > L320
McFarTech
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
L405 L495 > L320
Guys.
I’m in two minds if I want to refurb and change colour on my current alloys. Can I ask. Will L405 or L495 alloys fit my 2013 L320?
Many thanks
Craig ===========================================
2013 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Orkney Grey with cream and black leather.
Post #592066 Thu Dec 19 2019 10:56am
Yes.
Post #592067 Thu Dec 19 2019 10:59am
McFarTech
Thanks mate.
I have 20” at the moment (oh errrrr) will 21” be ok. I assume going up to 22” is to much and the ride be Censored ?
Post #592068 Thu Dec 19 2019 11:05am
Been running 21" SVR rims on mine for over 4 years and never had a issue.
Post #592069 Thu Dec 19 2019 11:10am
McFarTech
Excellent. ===========================================
Post #592070 Thu Dec 19 2019 11:12am
McFarTech
Might have my eye on a nice set of 22” off a 2015 Autobiography.
Do I need to do anything or worry about speedo or mileage being out? Can I correct this ? ===========================================
Post #592197 Sun Dec 22 2019 9:54am
McFarTech
I’ve bought some 21’s coming early next week. However the question still stands regarding my speedo and mileage being out? Will this be the case? Anything I can do about it?
Thanks in advance. ===========================================
Post #592462 Sat Dec 28 2019 5:23pm
knwatkins
Your speedo will likely be more accurate because they read low by default. Monitor your speed on your phone via GPS and compare with your speedo to see how accurate it is.
You can adjust the tyre size in the CCF with an IID tool or similar but I haven't bothered since fitting my 255/55/20 tyres. Kev
Post #592463 Sat Dec 28 2019 5:51pm
McFarTech
Thanks mate. the alloys are coming with 275/45/21 ===========================================
Post #592465 Sat Dec 28 2019 6:15pm
McFarTech
Silly question.
I assume my current wheel bolts on my 20" wheels will be ok on the 21"
both 20 and 21" alloys are genuine Land Rover ===========================================
Post #592467 Sat Dec 28 2019 6:21pm
Original L/R wheel nuts will be fine, don't bother changing anything in the CCF files it won't make any difference except screw up the cruise control speed compared to actual vehicle speed, or at least that's what mine did so left it at factory setting. As far as speedo is concerned it will it be just about spot on
Post #592472 Sat Dec 28 2019 8:49pm
McFarTech
Thanks mate ===========================================
Post #592487 Sat Dec 28 2019 11:07pm
