![]() | Home > Technical > Passenger and rear door won't open |
mikewill53 Member Since: 14 Sep 2018 Location: Swansea Posts: 35 ![]() ![]() ![]() |
Hi
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
The lock motors are a common fault, it would seem (I've had one of mine done).. easy to do yourself if you can open the door - I couldn't, and it had just failed the MOT (not being able to open the door is an MOT fail) so I paid the local indy to fix it; I didn't want to be able to see what they had to do to get the door open |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
As above ...your door locks have two small motors in them similar in size to a scalectrix car... these fail with age and need to be replaced...search on here how to do it....or search you tube on how to do it... |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
Must be something to do with the colder weather as I've been having intermittent door lock issues since the weather has become colder.
Hi
