Home > General > Engine decarbonisation |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
You'd be better chucking your money down the drain. Makes no difference whatsoever |
Mon Dec 16 2019 7:12am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I don’t know what this involves.
Mon Dec 16 2019 7:31am |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
I had mine done recently, and at the time I had a slight exhaust manifold leak which was only apparent under severe acceleration.
Mon Dec 16 2019 8:12am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Snake oil? Visitor from fullfatrr.com
Mon Dec 16 2019 12:05pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
Having taken the plastic Y pipe out of my engine when I blanked the EGRs and cleaned it up, I doubt any "chemical cleaner" is able to to the job - required pure manual effort as the various chemicals I used did not have much effect - this included carb cleaner, brake cleaner, petrol, diesel, degreaser etc. The gunk had to be scraped out by hand using things like screw drivers and thin scrapers and only when all the heavy stuff was removed could the last bit be removed by various chemical.
Mon Dec 16 2019 1:24pm |
Each to their own, I bet there are those who swear AR6900-D works whilst others say it's a waste of money, similarily some will have recently voted Labour and others Conserative, both 100% sure they views were right.
Mon Dec 16 2019 3:05pm |
Wwonder Member Since: 07 May 2019 Location: London Posts: 13 |
Hi guys
Tue Dec 17 2019 12:26am |
The proof is in checking how much crap is still in the system after you put the product through the engine - experience is that it is all still there. 07MY RRS TDV6
Tue Dec 17 2019 12:28am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1175 |
At 12 years old, Orxy got a well-deserved carbon clean - look at how much gunk had accumulated there 😳
Fri Mar 04 2022 1:54pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
naks - that's blast cleaning using a granular material, not a chemical clean using a fuel additive such as the TerraClean system. 2012 SDV6 - it's missing a couple of cylinders
Fri Mar 04 2022 3:21pm |
indeed, that workshop uses walnut I think --
Fri Mar 04 2022 3:43pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
My 2010 TDV8 has done short trips since new. The vehicle does around two trips very day of around 8km (to school and back) and no decarbonisation has been required - whatever that is.
Fri Mar 04 2022 5:47pm |
