Home > General (L494) > SVR Active Exhaust Butterfly Valve Rattle On Start Up
carlos50
Hi all
On my 2016 SVR, the left side exhaust rattles on start up whilst the idle is up, the butterfly valve for the active exhaust is vibrating. Once the idle settles or I press the active exhaust button the rattle stops.
Im considering replacing the actuator that sits on top of the rear silencer on that side on the assumption that the valve is not being held in position correctly, what do you guys think, replace it or take it off as can be fixed? Can I remove without dropping the exhaust?
Thanks
Carl
Post #591581 Sat Dec 07 2019 12:48pm
