![]() | Home > General > Advice needed |
andyslandy Member Since: 20 Oct 2019 Location: Chesterfield Posts: 142 ![]() ![]() ![]() |
Firstly welcome to the fold and sorry to hear of the problem, if i was you i would contact the place that did the work and explain everything to them whilst keeping calm as this makes it hard for them to get stroppy, make a note of their replies should you need to take it further. It might be worth contacting the trading standards office at County Offices in Matlock to get some sound advice and they will talk you through it. Good luck, Andy. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
check the oil level on the dip stick. Is there oil on it, or is the engine empty of oil ?
Riley76 Member Since: 04 Dec 2019 Location: Derbyshire Posts: 3 ![]() ![]() ![]() |
The oil is still measuring as on max (receipt from turbo work day before lists oil and filter change) but at the time it broke down it was raining and due to this could see a small amount of oil in spots down the road about every foot or so.i was intending to cut my losses and accept a offer for £1800 spares/repairs I going to be 5000 quid out of pocket but can’t justify spending another 2-3k on it especially with Xmas so close. Thanks |
Thank you Andy and I hear your advice and it sunk in....shouting and screaming at a garage owner/staff will be the least help.the garage I used was very nice and said if it’s there fault they will repair for free but its difficult to prove and most likely be inconclusive due to mileage and age. Learned a hard expensive lesson from it and I will own another at some point but will try saving up longer and get one a lot newer thank you Andy |
