Home > Technical > Remote Climate?
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Remote Climate?
So I went out to my car this morning having used the remote climate to warm it through, it was pretty cold and frosty when I finished work so thought warming it and defrosting would be just the ticket.
When I got in the car was cold, no air circulating which I thought strange - I started the car up and a message flashed up saying ‘Timed climate not available’ but it disappeared before I could see what else it said.
The remote fob flashed orange, then went green and blinked green which as far I am aware is the normal procedure.
It’s obviously just been in for service so could something have been reset during service?
The ‘Timed Climate’ option in the car both say ‘Off’ but I am assuming they would only say ‘On’ if you had set the time?
Si 2012 RRS HSE SDV6 - current
2006 911 Carrera convertible
2016 L200 Barbarian pickup
2010 RRS Lux
2008 E93 M3
2004 VX220 Turbo Stg 2
2010 E70 X5 30d M Sport
2006 Golf R32
Post #591304 Sun Dec 01 2019 1:53pm
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
One of the things it might have been is that the battery voltage was to low, can’t remember the exact figure but it has to be above a certain value to allow the heater to run,
Post #591308 Sun Dec 01 2019 2:25pm
ilard
Timed Climate should be off, yes, if you’re only using the key fob. An orange light followed by green blips is normal.
I agree with david007, sounds like a battery issue, maybe it’s dropping voltage in the cold if it’s approaching end of life. Low battery is displayed in the instrument binnacle when this happens. The climate may have started and then soon after decided to shut down, hence the key fob looking initially happy. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #591343 Mon Dec 02 2019 10:01am
Bodsy
Site Sponsor
Orange light on the plipper first means the fob battery is low. Change the battery and try again. Type 1/3N battery. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #591390 Mon Dec 02 2019 9:42pm
knwatkins
I agree with the above. Probably battery voltage low due to the cold. It used to happen all the time on my old battery. Since I've put my new battery on, it fires up every time without fail.
I love hopping into the toasty RRS on a frosty morning slipping my hot mug of tea driving past others defrosting their windscreens Very Happy Kev
Post #591391 Mon Dec 02 2019 9:43pm
aaronjb
The trouble with working from home is that I never get to experience that kind of smugness Razz Laughing
.. because I'm outside scraping the ice off the OHs MINI so she can go to work Big Cry Big Cry Laughing 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #591405 Tue Dec 03 2019 9:20am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
For timed or remote climate to operate you must have the following:-
sufficient battery charge
at least a quarter of a tank of fuel
outside temperature less than 15 deg C
Post #591412 Tue Dec 03 2019 11:44am
