Home > Maintenance & Modifications > Battery trickle charger - thoughts on this please |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Thoughts on this please
Sat Nov 30 2019 5:10pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I use a ctek, does lead acid and AGM, trickle and reconditioning. Bit more expensive but try Black Friday deals. I bought the extension lead and charge via the white tow electric plug using a connector from the site shop. Might have been the Disco3 shop. |
Sat Nov 30 2019 6:59pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
Ad says it' has a 4 amp max charge and only suitable for engines up to 2.5l . Don't know why it would mention engine size but if you are going to be using it on a regular basis I would spend a little more and maybe get a ctek 2010 RRS, TDV8
Sat Nov 30 2019 8:04pm |
Sun Dec 01 2019 5:25pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4985 |
I use a ctek 4 amp without issue on RRS |
Sun Dec 01 2019 6:08pm |
My car is used pretty much everyday, mostly 64 miles a day. My wife takes it sometimes and it’s only 6 miles a day. My cars to old old to have stop start, but it’s just sympathetic top up for the fleet. 2006 2.7 TDV6 HSE in Cairns Blue. |
Sun Dec 01 2019 6:14pm |
